mamba max1
mamba max1's Avatar
06.12.2011, 01:40 AM
You could use a shim (aluminum foil) around an 8x16x6 bearing which is more common.
Edit: 8x19x6 is also common...
Good idea, but these will be the outer wheel bearings in the revo knuckles. Not sure if I want to go that route. Now why did Hot Racing have to go and use a 17mm bearing.
