mamba max1
mamba max1's Avatar
06.12.2011, 01:53 AM
Wait...which HR knuckles? The only ones I see on their site use the 6x13x5 bearings...
I'm not sure the style I have is made anymore...can't seem to find them anywhere.
The knuckles I have use 6x17x6 bearings. I'm wanting to use Losi XXL driveshafts. That's why I need the 8mm bore. I wouldn't mind using a 8x16x6 bearing, I just wouldn't want to shim it with aluminum foil. Is there a better shim option out there? I'm not sure if a metal sleeve that is .5mm thick and 17mm in diameter exists?
