Hyper-5
The-Hyper One
Hyper-5's Avatar
06.20.2011, 05:33 AM
Originally Posted by ransom View Post
yes it does sound like a bad solder joint or battery connector or the esc is hitting low voltage cuttoff
is it a new install? new esc ?
is it set for the packs you are using?
check settings on the program card
if you dont have a program card for your xerun then you need one
it says 5.1v, on the speedometer, its sorta a new esc, the rest are all yes's
heres some pics of the join to the ESC, and the connection to the second plug og the ESC (in series)
seconf plug to ESC
plug from ESC thats goes into the battery
ransom
06.20.2011, 06:54 AM
um thats terrible looking soldering dude
what size and configuration are you trying to run it on ?
and it looks like you have a series harness with a dodgy jumper on one side
and some extra wires on the other side ??(bec?)
could you take a pic of the whole layout ? looks really suspect from what we can see
Hyper-5
The-Hyper One
Hyper-5's Avatar
06.20.2011, 07:05 AM
ye it is a BEC, lm running 11.1v 3s lipo,
