rckcrwlr
Where are the Rocks????
rckcrwlr's Avatar
06.21.2011, 03:50 PM
Originally Posted by NickRummy View Post
Nice! Are you using a steel spur or plastic? Are you still running the stock flux motor? I just posted a thread with my project.
Steel spur and stock motor. Haven't had issues with heat. I see you are running wider tires. I'm running 5B Trenchers. The tread is harder and narrower but they are heavier than what you are running.
Bought my Wife a Rock Garden :027:
NickRummy
NickRummy's Avatar
06.21.2011, 04:01 PM
Actually, that's just what came on the roller I got. I'm using the 5SC wheels and tires. Got halfway through putting them together on lunch break today. I'm hoping today to have the wheels and tires mounted on the roller so I can get an idea of track width.
rckcrwlr
rckcrwlr's Avatar
06.21.2011, 04:04 PM
You are going to need the 24mm hex adapters for the Baja Wheels...
NickRummy
NickRummy's Avatar
06.21.2011, 04:10 PM
Got em sitting on my desk. Question is, do I need to get XL stubs.....
thzero
06.21.2011, 04:16 PM
Yes, and do my customization using the BAJA 24mm hex hubs that came with the 5SC.
NickRummy
NickRummy's Avatar
06.21.2011, 04:30 PM
Problem is I'd have to get the rears. I'll definitely keep it in mind though.
thzero
06.21.2011, 04:11 PM
Those are good, but they suck because of Savage axle design. Nick knows about my solution, since he did them for me, so I would highly suggest that. Yes you lose a tad bit of width, but its a much studier solution (I posted it in my thread about my 5T here at RCM). I went through at least four axles where I busted it at the end of the threads; rather expensive.
NickRummy
NickRummy's Avatar
Oh crap, is this Chris?! How's it going man! I'm hoping to work on a newer design that'll give me more width......
thzero
06.21.2011, 04:21 PM
Ya; it goes ok. More width would be good, but as they were they certainly worked much better than just 23mm or 24mm hubs for the Savage.
But speaking of, I'd still like to know what it'd be to do up a set of 24mm hubs for my RC8T. ;)
Haven't had issues with mine yet...must not be beating it hard enough.
Guess not... flog the b**tch :)
rckcrwlr
rckcrwlr's Avatar
06.21.2011, 04:18 PM
