rcankas Savage Flux XL
rcanka
rcanka's Avatar
rcankas Savage Flux XL - 07.05.2011, 08:06 AM
I thought I should start my RC-Monster posting with this post about my ride.
To this day it has the following setup:
HPI Savage Flux HP
Wheelbase Conversion Kit (#102404)
Savage Suspension Conversion Set (#87245)
KrakenRC Savage Flux Titanium Shock Shaft ( http://www.krakenrc.com/index.php/pr...ucts/view/2/10 )
Roll cage INFIN80 from Ma1n5t with an extra front crossbar and the EL8 Rhino Horn
Alza-Racing Motor Plate XL-size for ESC mounting (http://www.alza-racing.com/)
Alza-Racing Servo Plate for large scale servo (http://www.alza-racing.com/)
BashCatRC Bulkhead Braces
Hitec HS-5755MG Quarter Scale Servo (http://www.hitecrcd.com/products/dig...hs-5755mg.html)
HPI HD Drivegear 18-23t
Also got screwed by Tonys Screws (http://www.tonysscrews.com/)
Bad Horsie sexy hawt socks (http://www.badhorsie.com/)
50k oil in the rear and 30k in the front
350 oil in the shocks
Turnigy 2s and 3s lipos
Some pics of the evilness:
Feel free to suggest other mods i should or should not do and most importantly:
Check my youtube channel for some nice vids of this and other beasts
rcanka
rcanka's Avatar
07.07.2011, 01:10 AM
Over 50 views and not a single comment?
Come on :)
_dV
07.07.2011, 06:41 AM
some good mods to create more stable handling.
why choose a large servo when you could have gotten the same torque from a standard size one? most standard sized titanium geared are durable enough. do you drive it from the ESC BEC?
50K rear and 30K front ..most ppl go the other way around though i usually put the same in both being primarily an offroad basher.
IMO the bashcat braces and especially the titanium shocks shafts are not needed. just my opinion though. I also would have went with offset wheels instead of the longer axles
Badlands stretched over half ups you are probably lacking compliance over small bumps. Unfortunately there are no really good MT tires available.
cool vids
Recommend mod - shock tower supports since your layout has nothing obstructing it.
rcanka
rcanka's Avatar
07.07.2011, 07:47 AM
cool vids
Large scale servo enabled me to not use a servo saver at all and the one i'm using is cheaper than the equivalent standard sized one.
I am using the ESC BEC, but if you can recommend me a better one I'd be one happy camper.
50k in the rear and 30k in the front is just because i like a little more oversteer than most :)
I'm thinking of getting trenchers, but what rims?
Also the shock tower support is an AWESOME idea, what did you use for it?
HPI Savage Flux HP, XL length, bashcat, ma1n5t, krakenRC, alza-racing...
Check out my YouTube channel for some excellent vids of mine and other beasts!
_dV
07.07.2011, 08:33 AM
I haven't tried not using a servo saver at all. Seems like steering would receive a lot of stress. I use the HD servo saver spring.
Trenchers are fairly heavy so you would need to gear down. Axial 8 spoke oversize seem to have a good rep for a 40 series wheel.
Shock tower supports were part of a custom XL build I did last year
http://www.rc-monster.com/forum/showthread.php?t=26870
rcanka
rcanka's Avatar
07.07.2011, 09:34 AM
I'm now using the stock flux gearing of 20/44, haven't thought about it before
What pinion do you think I should go for?
I'm waiting on a 47t plastic spur, to have a cheap point of failure in case of a jam in the driveline.
And yeah, definitely doing the shock tower supports, thanks a bunch for that one :)
_dV
07.08.2011, 08:59 AM
The tie rods ends are standard Savage Flux tie rod ends. Joining them is a cheap m4 bolt. m3 bolt cut to size holds it to the chassis. You also need a longer shock bolt, think I used the same ones that go through the top of the roll bar.
47 spur with a 20 pinion will be about the same as the 44 with a 19 pinion. you might need to gear a bit lower then that. just keep an eye on your motor temps.
rcanka
rcanka's Avatar
07.08.2011, 12:09 PM
Thanks again, dV.
Will gearing like 16/47 give me more or less controllability in the air?
josh9mille
josh9mille's Avatar
07.08.2011, 05:45 PM
IMO the titanium shocks shafts are not needed. just my opinion though. I also would have went with offset wheels ]
I snapped off the of the stockers in the few outing with my flux, the ti-ni coated ones have been an excellent upgrade and I havent snapped any so far.
_dV
07.08.2011, 08:33 PM
You don't hear of too many ppl breaking them. I broke the threaded end off one early on but that was landing on a rock after some serious air. Since then nothing in too many runs to count. I have a suspicion though it might be to do with the shock tower supports. They keep the shocks lined up correctly. With the amount the tower can bend its bound to put stress on them.
_dV
07.08.2011, 08:40 PM
Thanks again, dV.
This is a difficult one to answer. Simple answer is that more than likely you will have less control. This will be because even though you will have heavier trenchers you won't have enough top speed to generate a decent change in angular momentum once your get into the air (for rotating backwards).
6S will probably make this less noticeable than 4S though with a 2200kV. 16/47 is very low gearing, total reduction is nearly 21.
Differential Ratio: 3.2222222222222223
Transmission Ratio: 2.215277777777778
Spur Tooth Count: 47
Pinion Tooth Count: 16
Total Voltage: 22.20 (6S)
Motor KV: 2200
Tire Diameter (inches): 6.3
Spur/Pinion Ratio: 2.94 : 1
Total Ratio: 20.96822 : 1
Tire Circumference (inches): 19.79 inches (502.72 mm)
Rollout: 0.94:1
Vehicle Speed: 43.66 mph (70.13 km/h)
rcanka
rcanka's Avatar
07.09.2011, 11:11 AM
I only intend to run 6s in the future, I think.
Thanks for the info yet again. :)
rcanka
rcanka's Avatar
07.10.2011, 07:31 AM
New vid up on youtube now! :)
