Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Overdriven
Destroyer of Tires
Overdriven's Avatar
07.07.2011, 07:58 PM
What you've created looks alot like an extended hex, except that it is in 2 pieces. What about taking an extended hex with an 8mm bore, and drill a hole for the drive pin in the correct location. It'll be all one piece, and might support the axle better. Only issue then is you might want to use a sleeve or something on the threaded portion of the axle. Just an observation, and throwing out an idea. Cool truck man, I love those bodies.
NickRummy
NickRummy's Avatar
07.14.2011, 01:52 PM
Exactly what I would want to do, build a one piece extended hex but there's a lot of machining time tied up in that 24mm hex with the threaded end. I'm hoping this will work well and it's way easier than machining a one piece part. Time will tell.
Alza motor mounts came in for the 1717.
Some clearance issues
"Trimmed" the TCS plates
