cmac
cmac's Avatar
08.13.2011, 02:02 PM
OK. I have the hinge pins in when I went to assemble them the Upper (longer) pin sits flush with the arm edges. I can't use the included clips to hold the pin in place. Correct me if I'm wrong but the ends of the pin should stick out far enough to use the c-clips. Did I order the wrong hinge pins? Remember I'm using UE supermaxx A-Arms. By the way I finally ordered the radio that is going to keep this under control.....http://www.rcsuperstore.com/Futaba_4...p/futk4901.htm It should be here on Tuesday or Wednesday.
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
