cmac
cmac's Avatar
08.13.2011, 04:50 PM
Well I just bought two sets of UE titanium hinge pins. I imagine they will work(they better!!!!!).
cmac
cmac's Avatar
08.13.2011, 10:56 PM
If I were to get a 4 pole Neu Castle motor would the ESC that came with my brushless Emaxx work with the new (Neu) motor? Or would I have to get another ESC?
WEB
08.14.2011, 12:27 AM
It wood work fine with what you have,it going to be a nice truck when you finish it keep up the good work.
dtnel
08.14.2011, 12:45 AM
Originally Posted by cmac View Post
Neil I bought the fast lane hinge pins. I really don't want to have to drill the arms or the bulks. what are my options?
The 14500 pins from flm are the ones for the hybrid bulkheads. THe 14500 has 3 different sizes whereas the 14000 only has 2 different size pins in the box. I Have the one with the 3 different size pins but I haven't installed mine either yet......
cmac
cmac's Avatar
08.14.2011, 07:13 AM
From the the picture the 1400 and the 1450 look the same. I have a set (1450) coming to the house. Between the UE titanium pins and the 1450 pins hopefully one set will work.
cmac
cmac's Avatar
08.14.2011, 07:15 AM
Thanks Web....
cmac
cmac's Avatar
08.14.2011, 08:20 AM
I just checked the label on the bag, and it is indeed the 14500. Only two size upper and lower pins, and the uppers are too short.
dtnel
08.14.2011, 08:57 AM
Thats definitely a oddity. I Have 3 sizes and you 2 from the same part no.
cmac
cmac's Avatar
08.14.2011, 09:37 AM
So there are two different types of upper a-arm pins "long" and "longer"? That would also mean that your bag would have 12 pins in it, right?
dtnel
08.14.2011, 02:54 PM
I have 8 in the bage. Note the 3 different sizes,
FLM 14500 hinge pins. 3 sizes, 8 total pins in the pack
dtnel
08.14.2011, 02:58 PM
I have 8 in the bag. Note the 3 different sizes,
I need to get my Ofna hyper 7 diffs shimmed so I can get them wrapped up but I drag my feet as usual. I did go and buy a box of the RC Screws this past week so this truck will get the silver bolts. Wish I had the money to color my chassis and such a purple or something like that though.
cmac
cmac's Avatar
08.14.2011, 02:59 PM
Thanks, I see. Are you going to use UE arms too? I think there is just more material on the outer parts of the upper A-Arms, and that's why the pins are not long enough. The bottom pins are perfect. I think the UE ti-pins will do the trick, and I will be able to use the Fast lane uppers on my original E-Maxx. Thanks dtnel.
cmac
cmac's Avatar
08.14.2011, 03:08 PM
I'm using RC screws as well.
cmac
cmac's Avatar
08.14.2011, 03:39 PM
Has anyone used one of these before?
http://cgi.ebay.com/US-RETAILER-Leop...item3f03c94b5c
what do you think? I like the fact that it is 4 pole.
dtnel
08.14.2011, 04:01 PM
I have the rpm true track on my old one that'll get converted over and the fronts will get swapped to rpm as well. I think when I'm done I'll be able to still have a 3rd emaxx (3905 spec) from all the extra parts since I have a complete motor setup as well. I have some decisions to make because I have 3 3906 trucks as well. I want one for water, one for a 3 axle project, one for a "pretty" truck, one for a basher.
I don't race so it looks like 2 of the oldest 3906 trucks will go or get parted out. I don't even think they'll bring much for parts on ebay unless someone is into restoring them as show trucks or something.
