Pdelcast
Pdelcast's Avatar
08.23.2011, 05:54 PM
Outrunners typically work better with higher timing. Try "normal" first. Also, depending on the vehicle/battery, start power can be raised also.
Because the CC controllers advance timing based on motor inductance, we usually recommend "low" timing for outrunners. So a little different than most sensorless controllers...
Thanx!
Patrick del Castillo
President, Principle Engineer
sikeston34m
sikeston34m's Avatar
08.23.2011, 06:05 PM
Yes, but he said a MM Esc.
Which MM is it though? I know the older versions of the MM didn't do so well with outrunners.
If it is an older MM, update the firmware and you will see a world of difference.
