The old novak motors had a plastic sleeve you had to insert down into the motor, then you could slip in the rotor so that the shaft entered the rear bearing with little effort- you could do something similar with the 1515 motor, but the sleeve needs to be stronger and made of non-metalic material ( bit of PVC plastic pipe should work ).
