True, the savvy location is crap. TBH I do not care for the truck design at all, but I seem to be in the minority there.
As for the lst you should be able to make a lower cg solution than the tdr setup. Just keep in mind the overall ratio and gearing options. Getting the motor as close to the trans as possible will yeild the most gearing choices.
