I too have that ESC and those plugs and also saw that tinning the wires beforehand wouldn't work. So, I twisted each pair together and worked at getting the untinned wire solidly in the plug. The plugs I got have a hole on each side. I just stuck my soldering iron tip into the hole, then heated the plug and wire until I was able to "feed" the solder in. It took a while but it worked.
