cmac
cmac's Avatar
10.29.2011, 06:54 PM
Hey cliff,
here you go. Keep in mind that I used the FLM center skid plate, and the measurements are from the center of the holes to the first edge of the plate, (there is a beveled edge) not the very edge of the plate. The template that came with my motor mount must have been for an older version of the motor mount as the holes did not line up to my assembled mount. I assembled the mount and made my own template. I'm not going to do a full build thread, but I will post some pics along the way. Good to know your starting your build. As far as the top plate I think mike had some top plates go out that were the wrong size. If you have the Slipper assembled it should fit in it with no play. If does not sit in it right then let Mike know. Are you using the FLM chassis? if so pay attention to where I notched the frame. You will have to do the same if you want to use the same length drive shafts. Have fun and if you have any questions I will help any way that I can.
Mike.
