RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
03.27.2006, 06:18 PM
Leroy was tearing the nubs off the stock maxx slipper kit. Nick is using a Jammin' truggy, which should hold up to quite a bit. The G2r doesn't have the diffs to handle the crazy power, but a 1940 with 5s or 6s should handily smoke the nitro just the same in the G2R. :)
Gustav
Gustav's Avatar
03.27.2006, 06:59 PM
Was it the little brass pins that key to the steel slipper plates?
For Lipos check out FMAdirect cellpro system(the 3200 20C packs),it's very userfriendly if you've not had lipos before,monitors each cell on charge and discharge,has it's own dedicated charger so it's as foolproof as possible.
I'm using flightpower/duralite evo 20c packs with a schulze 330D charger,polyquest 'twenty' seem to be the same cells.
Lots of good lipos around,go for ones with a high discharge rating and with balance taps installed.
