11.29.2011, 10:34 PM
Originally Posted by BIG-block View Post
...Brushless motors speed is determined by it's kv and voltage that it is being fed. Maybe some motors might be a bit slower to spool up but they should theoretically still reach their kv X Voltage speed. (unless the motor is way under powered or battery voltage drops under load) At least that is my understanding of it. Happy to be corrected though...
Actually, higher timing can increase motor rpm to beyond the kv*voltage calculation. How much extra speed vs how much timing vs wasted heat takes some experimenting though.
