Stock tire/rim size is a 30 series correct for Losi 10T -
11.25.2011, 06:58 PM
just picked up a new one that was never used cheap and it has the RCM conversion! It just needed shocks and tires...I have a set of shocks so no biggie there. The tires I believe are a different size than 2.2 if memory serves me. Now, the other questin is which one of these will fit, front or rear or do I need one of each....
http://www.amainhobbies.com/product_...Wheels-Black-2
Site Owner
11.25.2011, 07:06 PM
the original wheels/tires were from a 1/10 buggy, actually. 2.2s are commonly used on these little beasts, though.
11.25.2011, 07:12 PM
Ok thanks Mike...I was searching BrianG's Ten T thread and in it you mentioned using 30 series wheels at some point due to axle sizes being different...or something like that anyway.
So, will the one's I mentioned above actually fit?
Site Owner
11.25.2011, 07:17 PM
30 series is basically a low-sidewall version of the 2.2(kind of like VTR vs MTR in truggy tires). - the 30 series wheels and tires will fit fine. :)
11.25.2011, 07:21 PM
Again, Mike, thanks for you input!
11.25.2011, 10:15 PM
out of curiosity, what are you guys running for tires on your ten t?
12.03.2011, 05:51 PM
Although the RCMonster answered my question regarding if the tires I listed above will fit, I am still unsure if I need a set of each or like the CRT.5, just the fronts
