brian015
brian015's Avatar
01.09.2012, 09:33 PM
The only time I had trouble with a pinion coming off like that was when my motor mount was misaligned, so the pinion was meshing at a slight angle with the spur. This produced a force on the pinion that pushed it outward toward the end of the motor shaft and it came off regularly, until I fixed the misalignment.
Thirdgen89GTA
You can sleep in a car, but you can't race a house
Thirdgen89GTA's Avatar
01.09.2012, 09:39 PM
I'll have to look at that. It didn't look crooked, but i also didn't consider the possibility that it could be crooked. I figured when the motor was tightened down it would flatten itself out as long as something wasn't between the motor and the mount.
  • 1989 Pontiac TransAm GTA, 5.7L LT1/M6 400rwhp+
    • Jammin X1 CRT Pro, MMM/1717, 6S
    • Hyper One Seven 1/7th scale GT car, MMM/1717, 6S
    • Hyper 10TT, MMP/1410, 3S
    • TL Mini 8ight, stock, 2S
  Send a message via AIM to Thirdgen89GTA
brian015
brian015's Avatar
01.09.2012, 09:40 PM
In my case, it was the motor mount itself that was misaligned, not the motor to the mount - if that makes sense.
Thirdgen89GTA
01.09.2012, 09:43 PM
I don't think that will be the case for me then. I'm using the factory drilled differential holes. All I did was switch the direction of the diff. So it should be fine.
