Go Back   RC-Monster Forums > Support Forums > Novak
Bob Novak
01.17.2012, 08:29 PM
Originally Posted by crazyjr View Post
Whats up with this? How close is the power between neo and this? I know you built it Primarily for heat resistance, but does the motor lose any power to the neo setup?
Neodymium (Neo) vs Samarium Cobalt (SmCo)
The output power of both of these rotors are very similar. Our motor design is based on a 28 MGOe energy product magnet and the SmCo is also rated at 28 MGOe (MegaGauseOerstead). The difference comes into play as they heat up. Since the SmCo Rotors have a very high coercivity (coercieve force), they are not easily demagnetized. Thus the SmCo Rotor can tolerate about 250-350 degree F more temperature rise than a Neo magnet before they began to lose their magnetic power.
The Curie temperature of a Neo magnet is around 320 degree C and SmCo magnets is around 800 degree C. What this means is if you heat a magnet without an external magnetic field the magnet will lose all its magnetic properties at the Curie temperature.
Also the coefficient of remanence of a SmCo magnet is about ¼ of Neo (-0.03%/C vs -0.12 %/C). Remanence is an indicator of materials ability to hold magnetization (magnetic storage). The lower coefficient shows a ¼ lower loss of magnetic force due to increase in operating temperature.
Of course you cannot run the motor this high a temperature due to other components in the motor but it will make the motor output power stay flatter for a longer time.
Bob Novak
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
