02.15.2012, 05:15 PM
Originally Posted by FG101C View Post
Maybe it means they put post's on that will take wire larger than 12awg without having to learn a new magic trick. Using one on my baja and it works but it was not easy getting the XL wires soldered on, still not comfortable with it.
Have you tried this: Tin the wires with solder. Then, using needle-nose pliers, "squish" the tinned area to flatten the area somewhat. That should reshape the wire enough to allow you to insert the flattened wire edge-wise into the solder-post groove.
I use this "trick" when soldering wires on Tekin ESC solder posts.
