general brushless question
sikeston34m
04.14.2012, 11:20 PM
You're better off to keep your power wires as short as possible.
Maybe put another connector set at the ESC, then use an adapter when you run twin packs.
It does sound like you have a bad connector or solder joint though.
That does tend to make things heat up.
sikeston34m
Find all posts by sikeston34m
