05.10.2012, 08:23 PM
I was thinking about this more last night...Brian you may be right. I currently have the set up that I was running on my crt.5 which is the pink spring 1.4lb and 35wt oil.
I have been hard on them as we go to a BMX track nearby and the air time can be impressive. I had the lower mounting hole in the middle so maybe I will move it a bit and retry with a stiffer spring and a little bit stiffer oil
As far as bottoming out....hence why I was looking for a little bit longer shock. The Ve8 front shocks may be the ticket as they are 10mm or so longer I believe
