brian015
brian015's Avatar
07.13.2012, 01:03 PM
I'll be interested to see this - so far so good.
I'm curious - which Neu motor (size/kv) are you using (I can't read the label)?
Jony Nitro
Jony Nitro's Avatar
07.13.2012, 01:16 PM
22173Y(425)Kv
D8T Brushless
Brushless Baja
SC10 Neu Power
brian015
brian015's Avatar
07.13.2012, 01:23 PM
Originally Posted by Jony Nitro View Post
22173Y(425)Kv
Thanks - and what voltage do you plan to run? 12s?
Jony Nitro
Jony Nitro's Avatar
07.13.2012, 03:04 PM
14s does that sound insane
D8T Brushless
Brushless Baja
SC10 Neu Power
brian015
brian015's Avatar
07.13.2012, 04:23 PM
12s, 14s, whatever it takes!
(Both will put you in the 20-22k rpm range - which should be a good place for the 22 series - I'm guessing, at least)
