millzee
millzee's Avatar
07.21.2012, 11:04 PM
in the xo-1, the shaft is a short 8mm round rod that holds the spur with bearings on either side, the slash has a longer 6mm round shaft with the spur and revo slipper system. I have checked and I believe a mod 1 46t spur and cush slipper system will fit if an 8mm round shaft the same length as the slash shaft with the xo-1 spur held into place where the slash spur should be, should be simple right? I'd like to run 46t spur with a 26t pinion, I recon this would make a nice set up in a slash powered by a 1/8th electronic system.
