nativepaul
nativepaul's Avatar
12.27.2013, 11:37 AM
Not that I know of but you could do the same thing by fitting a bigger 2s pack than you need, if it doesnt deplete fully you will have more volts at the end.
Xray XT8, 1518, MMM, 4s5Ah.
Lots of boats.
fastelectrics.net
whitrzac
Can't catch this...
whitrzac's Avatar
12.27.2013, 12:02 PM
It would lessen the issue, but I'm already running a 6000mah pack...
ta_man
12.28.2013, 10:46 AM
You can now get 8000 to 10000 2S packs.
Alternatively, choose a motor that has a peak RPM that is about 60% of your current peak RPM. Being lower KV, it will draw less current and give you the same effect. Example: I ran a 8.5 turn 550 motor on 3S instead of a 4.5/5.5 motor on 2S. The motor barely got warm and the rather small 3S pack (3400 mAHr) would only be drained about 50% in a 10 minute race. Now you can get 3S packs with 4300 mAHr capacity that are the same size as the standard 2S packs.
