FG wheel adapters
Big House
Big House's Avatar
FG wheel adapters - 08.27.2014, 05:32 PM
Ruud,
Here are the pics of the adapters on the axle. They are connected by two 6mm grub screws that connect to the axle hub. The bore in the adapter is 8mm so they will fit on the axle. Here is the adapter on the truck. I used a bearing as a spacer. This is the wheel I am running as well.
Name:	FG wheel adapter 1.jpg
ID:	10777   Click image for larger version
Name:	Deltaplastik wheel.jpg
CF Ofna DM-1 Pro CC1717
CF Sportswerks Mayhem ST
CF Losi LST2
