Originally Posted by Pdelcast
Not exactly. Cryo-drive is more sophisticated than synchronous rectification -- it's a true active freewheeling.
OK, good news, since it's the only big feature missing in castle prodcut, mainly air ESC for partial throttle with with some power load, like helicopter and less with ground ESC even if my MMX in 13lbs car (hpi apache sc) is a little affected by heat at partial throttle and get pretty hot quickly with the fan almost always on (with 10Ah 4S battery).
Can you tell if the other ESC like MMX will receive the software update to enable cryodrive equivalent ? Thx a lot !
