maxxximatoze
08.21.2018, 06:10 AM
While true, there are also instances when active freewheeling reduces efficiency significantly.
Cryodrive is more sophisticated than simple AFW, and results in efficiency gains across the board.
OK, it seems to be a very cool feature (in every senses of th word) ! What do you mean "instances when active freewheeling reduces efficiency significantly" ? Do you know if the hardware in the MMX can be compatible with this new software feature ? Tia.
