maxxximatoze
10.01.2018, 04:59 AM
1. About 170 microohms
2. About 2.2A
3. About 1200 watts (5 minutes)
You would certainly say 1.7 milliohm A to B, B to C and A to C at the bullet connectors ??? How it is possible with around already 1 milliohm of 8AWG wire resistance ? Maybe it's 1.7milliohmresistance per winding and so it's 3.4 milliohm phase to phase + 1 milliohm of wire = 4.4 milliohm at the bullets (AtoB, BtoC, AtoC) as you always measure them by two in Y motor, am I right ?
For example the DBXL-E motor at bullet (1.5 turn Y) is 5.8milliohm with 1.15 millohm of wire (8AWG 28cm lenght x2) so it is around 4.65milliohm AtoB, etc... so 2.32milliohm per winding (not directly measurable as connected inside the motor).
Is the 2.2A I0 current at 32V ? Because it is very very low !, the DBXL-E is at 4.2A@32V
If these parameters are real I'm going to run out to the store to buy it today !
