Originally Posted by fishmasterdan
O ya 1 more thing. The 8xl has the 5.5 mm pins (I think). Wouldnt it be a better connection if it was direct soldered into the connectors like you do with planes??
Those 5.5mm connectors are rated at 200amps continuous. Deans are rated at 60amps. Deans have a lower resistance than a peice of 12 gauge wire the same length as them, so I wouldn't worry too much about the 5.5mm gold connectors.....
