motor mount screws
tallyram
tallyram's Avatar
motor mount screws - 04.13.2006, 09:29 PM
i've got an lmt 1950 motor that will be mounted to a traxxas emaxx motor plate that is 4mm thick. add 2.5mm for the depth of the hole in the motor. add .2mm for the thickness of the washer. do i need a 6.7mm long screw. where can i get a length like this? please help.
  Send a message via AIM to tallyram
tallyram
tallyram's Avatar
04.13.2006, 09:32 PM
do i just use 2 or 3 washers to compensate for a screw that is to long?
MetalMan
MetalMan's Avatar
04.13.2006, 09:50 PM
If you have a Dremel, you could cut the screw down. As opposed to using extra washers, this method will provide a stronger hold.
squeeforever
squeeforever's Avatar
04.13.2006, 10:33 PM
if you do that just remember to put a nut on it before you cut it shorter so when you cut it you can unscew if and clean up the threads.
tallyram
tallyram's Avatar
04.14.2006, 07:16 AM
thanks guys, i'll give it a try.
