neweuser
neweuser's Avatar
04.22.2006, 09:14 PM
I soldering in parallel. Just to be sure. THe pos goes to the pos side dean, the neg goes on the neg side of another dean. Then when connecting the two the pos side should be technically correct, the negative side should have neg where the pos should technically be...is this right? The diagram above for it looks like they have the pos wire from controller going to the negative side of the dean though
