This is a dumb question, as i'm sure i have asked many by now. But the male connectors, what is the best way to attach them to the wire to the controller?:007:
just dump solder in the holes on the side of the connector? they a goldish, will the solder stick ok? if i use a little flux? makes sense, can you confirm??? thanks again mills man!!!!
And you gotta get those plugs and wires hot so the solder bonds to the metal. Even if the solder itself melts, it might not bond to the connector/wire unless both are hot enough. Cold solder joint=bad connection=hot connector under high amperage and a little less voltage at your motor.
