coolhandcountry
coolhandcountry's Avatar
06.14.2006, 08:49 PM
The spring controls the hieght of the shocks and truck. The oil controls the dampening.
phidailo
06.14.2006, 08:59 PM
thanks...so what wt oil should I use
  Send a message via AIM to phidailo
giftacrylic
RC-Monster G-Maxx
giftacrylic's Avatar
06.14.2006, 09:20 PM
Did you try the outermost hole in the A-Arm? It will give a firm ride and still give a plush ride at the extended position.
Try several combos of springs and oils. I use 60 wt oil in the bypass, 30 wt in the coil overs w/ the FLM towers. Also use the stock springs.
phidailo
06.14.2006, 10:04 PM
I will give that a try and let you know
phidailo
06.15.2006, 02:37 AM
Adjusted the shock positions and it does make a big difference but there is still a slight sag. Well, I put in an order for the firm and ultra firm springs. I plan on using 40 wt in the coil-overs and 50 wt in the bypass.
What's the proper way to change out the oil in the bypass since I've already put 40 in there?
