Wheelie Bar
andy
Wheelie Bar - 04.11.2005, 05:08 AM
Since I am going to change my whole screws in stainless steel torx at the next weekend,
I have to disassemble the wheelie bar as well. I will post the pics from the parts.
Yes, I painted the Body by myself, this was very easy. Just print the desired design on a stickfoil
(use for example protective foil that is used to wrap books).
First Step: Print the sheet twice. Cut the Flames on the outside of the black line, stick them
on the body and paint the Body in the desired color (my Body is Gun Metal Grey)
Second Step: Remove the Flame-Foil from the Body. Cut the Flames on the inside of the
Black line and stick the Flames again in the Body, now you can paint the outlines in the desired color.
Remove the Flame-Foil and paint the Flammes in the desired color.
