Turnbuckle ends
phidailo
Turnbuckle ends - 07.11.2006, 08:51 PM
You know where I can get aluminum ends for the turnbuckle? The threads on the plastic ones in the front stripped.
  Send a message via AIM to phidailo
squeeforever
squeeforever's Avatar
07.11.2006, 10:20 PM
I would stick with plastic. Somethings gotta give and not to mention, they will mess up your toe in adjustments.
phidailo
07.11.2006, 11:01 PM
thanks
will the RPM rod ends work?
http://www2.towerhobbies.com/cgi-bin...?&I=LXALN0&P=7
If these do work, how are they secured since the hole is not hollow?
squeeforever
07.11.2006, 11:32 PM
Those won't. There for TC's, 1/10th's, ect. There designed for a ball stud and not a hollow ball. I don't particulary like them because they pop off easily.
emaxxdriver18
07.12.2006, 11:36 AM
these should work good http://www2.towerhobbies.com/cgi-bin...?&I=LXEMD2&P=7
