HotnCold
HotnCold's Avatar
04.23.2005, 07:00 AM
Well - it looks like serum hit that one on the head - The only thing I could add is definately stick with the stock body posts. I have smashed mine a bunch of times and I will gladly replace the little plastic mounts rather than using alum body posts and replacing bent shocktowers or snapped bulkheads from impact. Get a couple of extra body posts and cut them after mounting the body so they dont stick up that far above the body. They only bend easier the farther up they stick - and when you cut them off - keep the cut off pieces for replacement when you break the mounted ones.... just my .78 cents...
Hows that "Hope and Change" working out for Ya???
