HotnCold
HotnCold's Avatar
08.03.2006, 09:28 PM
if you want a cheap way to lock the tranny in a gear - use a metal wire from the tranny shaft and secure it to a screw on the tranny. Loosen a screw close to the shaft and tighten the wire on it - then retighten the trans screw. Thats what i did back in the day... Good luck
Hows that "Hope and Change" working out for Ya???
