Originally Posted by danverz
Ciao,
go for the hi-amp version.
The "normal" one has 3 female 3.5 gold plated connectors made by 2 parts joined together
by pression. It's easy to break off them. I broke off one of them early in my bashing.
Another thing I do not like about the "normal" version is that the current drawing can go
up to 100 Ampere and that 3.5 bullet connectors risk to be a resistent point for the current
flow. If just one phase has an higher resistence, makes the controller heating up.
So I say go for the hi-amp version, do not use any connectors, keep the cables as short as
possible, and finally use a silver solder pond.
Just my 2 cents,
Ciao,
Daniele
I wouldn't worry about the connectors. If you are, just get the 5.5mm connectors. There rated for something like 200 amps I believe.
