Gustav
Gustav's Avatar
08.21.2006, 03:28 AM
The only problem i can see are the diffs,they look the same as the TLTs,all the axle parts look the same except for the cases which look a little different,presumably for the leaf springs and to look a little more scale.
It's not a major problem,wouldn't stop me buying one 'cause it looks awesome,like a bruiser but affordable. it's just the diff gears are pot metal and they can break with BL power and there's alot of screws to swap them out.i speak from experience.Spares are cheap though and the slipper should help alot.It's not the sort of truck you'd want masses of power in anyway,6 cells would be enough i think.
