TOP CHASSIS PLATE 246
BOTTOM CHASSIS PLATE 234
TRANSMISSION 286
FRONT & REAR DIFFS 354
OUTER CVDS (4X) 234
FRONT CENTER CVD 34
REAR CENTER CVD 72
FRONT BULKHEADS 128
REAR BULKHEADS 118
HUMMER BODY
FRONT SHOCK TOWER 113
REAR SHOCKTOWER 113
POWER-STROKE SHOCKS (8X) 352
REAR SKID PLATE 82
FRONT SKID PLATE 96
FRONT BUMPER 88
REAR BUMPER 78
UPPER A-ARMS (4X) 232
LOWER A-ARMS (4X) 228
RECEIVER & COVER 66
SHIFTING SERVO 52
1/4 SCALE STEERING SERVO 160
2280 MOTOR 870
MOTOR BRACKET 132
MOTOR COOLING FANS (2X) 90
MGM ESC + BEC + FANS (2X) 246
WHEELS & TIRES (4X) & NUTS 1520
STEERING KNUCKLES (4X) 148
ESC MOUNT & MOTOR SUPPORT 28
FRONT TIE ROD END & STEERING ARMS 44
REAR TIE ROD END 36
CHASSIS BRASE (2X) 96
A-ARM HINGE PINS 36
6612 grams (14.57Lbs) TOTAL.. without batteries..
12 Cells 7450 grams (16.45Lbs) still too heavy.. I think the tires and wheels are the problems...
I would ditch:
REAR BUMPER 78
TRANSMISSION 286 (Get single speed)
SHIFTING SERVO 52 (Get single speed)
WHEELS & TIRES (4X) & NUTS 1520 (go for some lighter ones)
and get 8s lipo 3700 Mah packs would save you massive weight
thanks... How much do those velocity 40 series wheels... they're super light... correct... for wheels and tires.. I would like to keep it under 1KG, I was thinking of that.. should I cut my upper a-arms.. the center part... just keep the outsides.. I'm gonna ditch the tranny and get a center diff.. I will use LiPo for sure.. I already have some packs... but they're only 10C packs.. I need better LiPo packs... I'm gonna try to get it under 12 Lbs... the integy a-arms are pretty light. But stock is the lightest.. maybe I'll just use stock A-Arms and Stock Shock tower.. anyone know the weight of these
12 Lbs without the batteries that is... are the new 3.3 Parts any stronger? or just different colour... how much more does the RPM A-arms, knuckles and shock towers weigh?... about the same as stocK?
you think it'll hold up to 4 Lbs of batters and 2 Lbs of motor?....
I think I'm gonna go buy the U&L a-arms and steering blocks today... You're using their bulkheads?..??? it didn't break yet?... how much lighter is it than the aluminum....
:), that's for the New G-Maxx project... but the heavy maxx is starting a diet already... I've got permission at work to be able to use the hydraulic iron worker... I think my Heavy E-Maxx is goin' to be less than 15Lbs with 24 Cells... I'll be very happy with that.....
Actually my mistake.. the Stock tires with maximizer beadlock is 2.150Kg (4.75Lbs)...
