Is there a bl setup that can be used to run in snow without frying everything ? q,s i'd realy like to be able to run electric cars in the winter and not go ni´tro:019:
I would be afraid snow would get on stuff and then melt from the heat and then "bad stuff" to happen. Maybe seal the whole interior and then come up with a heatsink/tube/heatpipe system that uses the snow as cooling.
The Mamba Max has a water resistant coating according to Shawn Palmer, who is one of the higher-ups at CC. If you look closely at the heatsink, you might be able to see some of the clear coating flaking off.
That coating must be thin indeed because I cannot see any type of coating especially on the main batt and motor wires. I think I'll just keep it dry to be safe. :dft012:
