jhautz
jhautz's Avatar
09.08.2006, 01:53 AM
OK. Got the 1515 installed... I think I'm gonna try running without a rear brace for a while and see what happens. It looks like it should be OK and there is just no damn room to put anything under the motor at this point. The rear suspension is literally right under the motor. Only a few mm clearance between the bottom of the motor and the springs. These revos sure don't have much room. You pretty much just have to pack it in there and make it work.
Side note... I just went from a 9XL to the 1515-2.5d. Just got in one 2 minute run in the dark to test the setup and reprogram the radio and ESC etc.... Can I say..... :dft008: Holly CR@P!!:010: In just a little short run I can tell a huge difference. Way more torque then the 9XL. And the 4 pole is unbelievably smooth at low speeds. Not even a hint of a cog. Can't wait to get in some runtime on it this weekend.:027:
to make it...
or break it...
Silent...But Deadly
