Cartwheels
09.12.2006, 11:06 PM
I misspoke, I have a 1515 1Y. Also, I'm running 4s, 6400mah UBEC and MM.
I ran the setup over the weekend. It works pretty darn good. Temps were good. I had a fan on the motor and the blades flew off. I had to stop to fix the bare wires. Then ran for another 12-15 min. Motor was at approx 150*F with no fan, MM was at about 125*F with a fan. Outside temps was about 91*
The Mamba Max is amazing. The Quark would have overheated. The MM does have more of a punchy feel. My gearing was 12/51. It may be geared a little low. Top speeds weren't bad, but it felt like I could go up a tooth on the pinion. I've run 4 other ESC in this buggy. All in all the MM is a very good way to go. I like how easy it is to progam and the fact that you can have custom cut off for the Lipos. If the Quark didn't thermal it might be up there too.
Glassdotor, I'm glad I took your advice!
Cartwheels/Muck
