Originally Posted by jhautz
According to their website you can.
But $55 for 4mm extention seems like alot to me.
i thought it's 12.7mm extention for the rear hubs.If you ran the setback arms together with these it's nearly like a 4-link trailing arm,i bet it would add a ton of on power steering.would look wierd though.might stress the bulks and hingepins too much though but i think the sliders could probably handle the angle because of a universal joint at each end.
i'm thinking of trying the hubs on my maxx which uses 3.3 stuff,have to run a single shock on the inside and remove the other lower shock mount from the arm for the slider to clear though.
