JB3231
JB3231's Avatar
09.16.2006, 07:37 PM
What is the 3080 Aqwut? I looked through the motors and don't see it.
I am looking to have more top end punch and much higher top speed than this guy.
http://www.youtube.com/watch?v=NzGW6...6358DF&index=1
Mine:
2007 Grizzly 700 EPS EFI
Sons:
BL E-Maxx
4S MA 4000 Lipo/MM ESC
Feigao 9XL 22/54 gearing
Gmaxx single speed
Brushless Revo under construction
cemetery gates
09.16.2006, 08:02 PM
ok jb3231, you need to run a UBEC or a receiver pack at over 10 cells or 3s lipo with the mamba max, BEC (battery elimination circuitry) regulates the voltage to the servo, if you shove to much voltage in it, it will blow.
GET THE MAMBA MAX 4600 WITH A 4 CELL LIPO!!!!!!!!!!!!!!!!!!!!!!
also the 3080 is a boat motor that is like 10kw or 13.5hp or something like that..............
JB3231
JB3231's Avatar
09.16.2006, 08:16 PM
The 4600 on 4s is faster than the 5700 on 3s. I will need to run a BEC for the servo's. Just stating what I am learning.
Battery and charger advice?
Lithium Polymer Battery RC Car 4000mah 4S 14.8V Pack
Is that the battery from Maxamps that I need to order? What charger, balancer, and BEC do I order?
Mine:
Sons:
BL E-Maxx
Gmaxx single speed
cemetery gates
09.16.2006, 08:25 PM
yes the 4600 is faster on 4s http://www.rc-monster.com/proddetail...MM_4600&cat=20
ans here is the ubec
http://www.rc-monster.com/proddetail...=6vubec&cat=21
you can safely run 4s on the mamba max with a UBEC, but i believe you will void the warranty.
charger maybe?
http://www.rc-monster.com/proddetail...531lipocharger
not sure about a balancer.......
JB3231
JB3231's Avatar
09.25.2006, 09:57 PM
charger maybe?
I just noticed the charger is DC input only. Is there a cheap power supply I can use for it? I can stick a car battery on the work bench and keep recharging it, but what a pain.
Mine:
Sons:
BL E-Maxx
Gmaxx single speed
