Serum
Serum's Avatar
09.15.2006, 11:33 AM
And i run 5S on my 7XL, that's pretty insane. I do get a nice runtime though.
An 8 or 9XL would be my choice.
neweuser
neweuser's Avatar
09.15.2006, 11:36 AM
Serum, does your motor get hot?
Serum
Serum's Avatar
09.15.2006, 11:39 AM
yes... burning hot...
but it's fast... :p
neweuser
neweuser's Avatar
09.15.2006, 11:46 AM
I bet! on 5s...18.5 volts! Yeah, real fast! i know my 9xl moves pretty good only geared 16/51! So yours must really move dude!
Serum
Serum's Avatar
09.15.2006, 11:51 AM
Voltage doesn't exactly stays 18.5V.. 14.6 is more what it's doing. The reason why i ordered the 5s2p.
Rcbros
Rcbros's Avatar
09.23.2006, 11:57 AM
Dafni, I have a 9L laying around and while I wait for my Wallet to magically fill up I'd like to run it.
You said you stopped running it because of issues. What were those issues? And did you ever find a suitable gearing for the motor.
If not, I'm not opposed to running brushed for now. What gearing did you use when you ran stock brushed. And did you run 14 cells on an EVX? How were the temps?
Thanks a bunch!
  Send a message via Yahoo to Rcbros Send a message via AIM to Rcbros
Serum
Serum's Avatar
09.23.2006, 02:26 PM
The temps are the issues, and if i remember correct a magnet split on the shaft, which is an isolated case. you can run it on 14 cells. It's a hot setup though. A heatsink and fans might be a wise idea.
Thunderbruiser
Thunderbruiser's Avatar
09.28.2006, 06:44 PM
i have a bl revo...first off what tires you guys recommend? second what servo horn can i use to get max throw on my servos
Caster Racing Team 09'
Sik Wit It Racing Crew Fo life
garage:
E-CRT.5 brushed for now 13x2 orion(tekin g20)2s 5200mah lipo
  Send a message via Yahoo to Thunderbruiser Send a message via AIM to Thunderbruiser
squeeforever
squeeforever's Avatar
09.28.2006, 06:49 PM
I've been wanting to try the Bandlands MT's...
BP-Revo
BMW M Power!
BP-Revo's Avatar
09.28.2006, 08:12 PM
So have I, those look like they would be some of the best all around tires.
crazyjr
crazyjr's Avatar
09.28.2006, 09:21 PM
I'm runing panther boas on hurricane wheels on my G2R and its hooked on everything fron hard packed with dusty top to grass(got a little of everything on this track)
Thunderbruiser
09.28.2006, 09:25 PM
should i run alminum hexes? cause i melted a plastic one along with the center of a rim lol
garage:
squeeforever
09.28.2006, 10:31 PM
Glue the 14mm plastic hexes in the rims. That should help some.
Serum
Serum's Avatar
09.29.2006, 01:24 AM
Yeah, CA glue them to the rim. use a wheel-shaft to tighten them while the glue is drying.
E-Maxx King
10.02.2006, 12:49 AM
Thats one of the best ones ive seen. Hows the handling?
