cadima
Smile 10.16.2006, 06:07 PM
Originally Posted by MetalMan
I've had no problems with the stock diff in the aluminum tranny case running 4s Lipo on either a Mamba Max 4600 or Feigao 540 12s (3000 kv). However, the stock diff didn't last more than a minute in a stock tranny case with the Mamba Max 4600 motor on 4s Lipo.
You're right, the plastic diffs will take some decent abuse. It just depends on your weight, tires and surface you run on, idler condition (very important), motor and gearing, etc. I obviously exceeded that limit, and needed a change. I am surprised to hear you have no problems with a Feigao on 4s! You must treat her well :027:
