thunderw0lf
05.15.2005, 08:54 PM
I have the 8s and the 7018 in my Stampede. I also have a reciever pack in it too. I do get some cogging at low speeds but it smooths out when it gets up to about walking speed. As for heat with the ESC, without a fan I was seeing temps of 170 and thermaling, when I put a small 5 volt fan over the ESC it keeps temps under 120 and no thermaling at all. The downside to adding a fan was I imediately got severe glitching that made it undriveable. I solved that by glueing tinfoil to cardboard and then making it 2 layers, now I only get glitching at a distance ; I'm guessing over 200 feet away. If your planning to use 15/84 gearing your gonna have a very hard time keeping the front tires on the ground. Mine is geared 18/84 and I have an RX pack mounted in front of the shock tower along with FLM shock tower and an aluminum brace and I can barely the front on the ground with a 6 cell pack, and here I was thinking about getting a 6s; that would've been way too much power.
The biggest problem I'm having with it now is stripping the diff gear. I strip them every time I run a 7 cell pack, I even tried being gentle on it tonight and accelerating slowly and stripped it anyways. The plastic diff gear holds up with a 6 cell pack but can't handle anymore for long. I'm trying to get a steel diff but it looks like Cold Fusion Racing is out of business, no reply to e-mails and the site is down.
(MIKE, have you been able to get ahold of Andy yet?)
Here's a couple shots of where I put the RX pack; the black plastic holder is the half with the screw holes for the HPI nitro Rush battery holder. I had bought it for a mod on another truck and I noticed the holes lined up perfectly with holes in the FLM shock tower, just had to come up with a stand off for it.
Here's a link to the battery holder if you decide to get it, not sure what other shock towers it'll line up with but if you decide to get the Fastlane Machine towers, Mike here has them.
HPI Nitro Rush Bumper and Battery Box set
