squeeforever
squeeforever's Avatar
10.24.2006, 07:55 PM
I dunno....Maybe I'm loosing it...Anywho, mine ways around 11lbs with 2 3S2P 8000mah packs :p. I need to see about those battery trays for the wider batteries...I had to modify mine for my LiPos and I don't particulary like it....I am gonna design one or modify Leroys for his MGT and get it machined. I will send you the file if you want. It is gonna be designed for the 51T spur, not the 65 like they came with though...I shouldn't really be a problem with the 4.3:1 diffs. If I were you, I would do a few mods. I would go with a 8mm axle conversion and Dace CRT 23mm hubs, and a buggy upper arm mod. I would also use set screws instead of the stock E-clips. Makes it easier to work on...
