neweuser
neweuser's Avatar
01.09.2007, 04:17 PM
Originally Posted by crazyjr
Even if it did it would need additional programming, like, cut-off 3v per cell, then, how many cells.
The way they have it there is less programming and still determines proper cut -off, the way you suggested is easier for everyone except for the programming people
Also takes up valuable memory
I agree with you crzy. It was just different is all. If it would have mentioned that in the instructions on what the cut off meant would be nice, then it would clarify as well without the additional programming, jsut an idea as most companies list the cut off per cell, so that is what I'm used to. But I like the idea they have with listing it as a sum.
